Civic '96 (intake & header)
Old 06-13-05, 04:46 PM
Handyman05
I have a Civic 96 EX (Vtech), can i run it without the factory intake??? Is there a way i can fix my cracked header? because it makes some nasty sounds. why do the lights inside the car doesn't work?
Old 06-13-05, 07:29 PM
hspr's Avatar
You have asked three questions.
1. I am sure there are after market intakes for your Honda.
2. If by header you mean exhaust manifold, then yes it can be fixed -- it or the gasket needs to be replaced. You might have some luck getting it welded if it is cracked in an accessible spot.
3. The interior light probably don't work because of a blown fuse, likely the result of a bad bulb.
