67 Gmc
Old 06-13-05, 09:10 PM
67 Gmc
having a problem with truck, when I drive it for a while when I get to a stop with the gear on drive start feeling like it;s going to turn off but if I change it to neutral or park doesn't do it, runs normaly; another problem that i have is that it's not charging the battery, alternator is good, new voltage regulator, new belts, any advise?, thanks in advance for your help.
Old 06-14-05, 03:21 AM
Soundsm like you need to idle up the carb a little. As far as the charging you need to check voltage at the alternator and make sure the charge wire is running back to the battery.
