1990 suburban turn signal flasher
could anyone tell me specifically where the turn signal flasher is on a 1990 chevy suburban? I found the hazard flasher, but i can't locate the turn signal flasher under the steering wheel.
maybe before you answer that, the turn signals don't work. the bulbs are fine and the hazards work, but when you turn on the turn signal absolutely nothing happens. could this be a flasher problem?
thanks!
thanks!
