84 nissan pickup
84 nissan pickup
Just got this pickup it uses gas like crazy it's just a four cylinder, what could be wrong timing, not sure what to look for
Well since you just got it and you want to fix it you should. Tune up, plugs, wires, cap and rotor. Air filter, you should also have the valves ajusted they are easy to check. What is the fuel mileage compared to what it should be? Is it carb or throtle body? It could be dumping too much gas, especially if its TBI.
