'90 mazda b2200 - bearing question
Old 06-15-05, 08:37 PM
diy femme
Talking '90 mazda b2200 - bearing question
hey,
i know this is kind of a silly question, but i have to take the bearings off of one side of my mazda (it whirrs loudly when you turn the wheel to the left or keep straight, but when you steer right it stops.... would i need to replace the left or right bearing? i appreciate any responses/advice...
cheers!
Old 06-16-05, 03:11 AM
it would probably be the right side but if it is making much noise at all you can probably tell for sure by just jacking the vehicle up and spinning each wheel by hand also worn bearings often cause excessive play that can be felt by grasping the tire and wiggling back and forth while it is off the ground.
