1995 windstar
Old 06-16-05, 11:10 AM
siles
1995 windstar
1995 windstar antifreeze mixed with oil any suggestion ?
Old 06-16-05, 11:23 AM
a head gasket probem is very likely especially on the 3.8liter models suggest not driving the vehicle at all until it is repaired.
Old 06-16-05, 06:45 PM
hspr's Avatar
Could also be a leaking transmission cooler (which is inside the radiator). Checking the level in the engine and the tranny will tell you which one. If this is the case a new rad and a full cooling system flush will fix the problem. Otherwise, head gasket it is . . .
Old 06-17-05, 06:40 AM
'95 3.8s did have head gasket issues
If it has not had a new head gasket yet I'd tend to lean towards that
Old 06-17-05, 06:59 AM
siles
Thanks for suggestion. Is three any in expansive way, rather than spending $ 2500 to $ 3000? (Rebuilt engine)
Old 06-17-05, 07:14 AM
Liquid glass, use to only be able to get it at the pharmacy but now some auto parts stores have it. Comes in about an 8 oz can, with directions. Pour into radiator get up to temp and shut down. let it sit and then drain all back out. I have used it and seen it work before. Don't think I would trust it as far as being dependable, but would prob try it.
Old 06-19-05, 08:40 AM
the_tow_guy's Avatar
Blown head gasket(s) doesn't equal engine replacement. Check around to see what a head gasket job would cost in your area. Be sure to specify BOTH sides. It'll be a lot less than $2500-3000.
Old 06-20-05, 12:00 PM
hopefully you havnt driven it too long with it in the condition that it is in? the bearings might be shot if you have.
