Fuel pump not working. Pump relay? Fuse?
Old 06-16-05, 10:44 PM
Barry (Or)
Unhappy Fuel pump not working. Pump relay? Fuse?
'93 Toyota Corolla, 5 speed, four door.
Don't hear the fuel pump coming on. Opened the nut on the top of the gas filter and to check and nothing is flowing.
Replaced part of the fuel pump assembly - just the pump and the screen-filter. (Didn't replace the whole fuel pump assembly.)
Where is the fuel pump relay and fuse? I looked in the owners manual and didn't see a fuse for the fuel pump. Maybe I didn't recognize the name?
Any other suggestions? Thanks for any help that you can give.
Old 06-17-05, 02:58 PM
Before you replaced the pump, did you actually check for voltage at the pump? You'll probably need an electric diagram for the fuel system and run some checks on it.
Old 06-18-05, 02:45 PM
You should run, not walk to your nearest autoparts store and get yourself a manual. Don't throw money into your car without doing it with knowledge.
Chiltons and Hayney both make $15 manuals, for this particular need I would go with Chiltons. Good luck
