Clutch adjustment95 GMC 1500 4x4
Old 06-22-05, 05:16 AM
alienz57
Need to know how to adjust a clutch on a 1995 gmc 1500 4x4. This is a hydralic system
Old 06-22-05, 07:29 AM
bad news
Hydraulic clutches are non adjustable the only thing that can be adjusted a little is the petal.Make sure the fluid is up to were it should be and make sure that the slave cyl goes in when you press the petal.
(this will require two people) Truck does not need to be running.
Old 06-22-05, 08:01 AM
Fords have bushings on the pedal assbly.. the chevy should have them too,,,,,,,,,,,when the bushings wear out you get the feeling that it needs adjusting. The fords i saw with worn out bushings caused the truck not to be able to shift into rev.......................
Trackbacks are On
Pingbacks are On
Refbacks are On
