Mazda Miata was missing a little now running rough
Old 06-22-05, 06:41 PM
E
1997 Mazda Miata, 43000 miles, plugs changed at 25000 miles. Was missing every now and then but now runs rough fairly often. Could this be plugs or plug wires or a fuel issue?
Old 06-23-05, 04:00 AM
B
probably is ignition related but it could be alot of things if its missing often it may have thrown a check engine light with a misfire code for which cylinder it is missing on if you have a check engine light on suggest having codes read and start there.
plug wires often will blow a hole in the spark plug boot it is usually visible as a white dot or burned spot if you look closely at each plug wire boot.
