1996 Chrysler Minivan Front Window Repair
I need to replace the power window motor on my 96 town & country. I am having trouble getting the door panel off - any help out there?
There should be a couple screws in the arm rest, and possibly a screw behind the inside doo handle, also there may be some round looking plastic things that kindda look like a pastic washer if it has those you can use a flat screw driver and pry them out and there will be screws behind them. after all screws are removed pull out on the panel make sure all fastners come out of dorr becreful not to pull them out of the back of the door panel.
