Clunk going into Reverse
Old 06-29-05, 09:30 AM
Hirsch's Avatar
I am driving an 89 Jeep Cherokee Ltd with 4x4 and the 4.0 engine w/ Auto trans. When I am fully stopped and put the shifter into Reverse, I hear a clunk, but only in that gear. Could that be a U-joint going? Thank you all in advance for any advice that you give.
Old 06-29-05, 11:56 AM
Big Orn's Avatar
Do you have a lift kit installed?
Things to check:
(1) Ujoints (as you thought)
(2) Loose Ubolts on rear differential
(3) Loose transmission mount
If you hear it farther up front it could be an engine mount.
Old 06-29-05, 12:08 PM
I'm casting my vote for U-joint
Runner up: loose diffy bolts
Have someone shift while you're outside-be safe-don't go under there
You should be able to isolate it pretty quick
Old 06-30-05, 12:37 PM
Hirsch's Avatar
Thank you much!! No lift kit. I will check the things mentioned. Hope it is something minor.
