Problem With Chrysler Cirrus - Can anyone help me.
Old 07-03-05, 11:13 PM
BDas
Problem solved thanks everyone
Problem Solved
Old 07-07-05, 05:31 PM
Check fire next time.Sounds llike a possible Crank shaft position sensor.
Old 07-07-05, 06:08 PM
Lugnut's Avatar
Do this quick and easy check. When the hot engine fails to start in that one hour window, check to see if the 'check engine' light is lit up while cranking. If it is not lit up, as it should be for every start, then that is a clue that the ignition module is bad.
