Cylinder misfires
Old 07-04-05, 12:13 PM
Cylinder misfires
Saturn 97SL2- 87K miles
OBDII Scanner was reading "Cylinder 1 misfire", but erased by itself. Now reading "Cylinder 2 misfire". Any ideas on what this means? and what can be done to fix it? Appreciate any assistance. Thank you.
Old 07-04-05, 01:31 PM
was it actually misfiring, or was it just saying that. if it was, it might be the coil pack.
Old 07-04-05, 02:09 PM
It could also be the fuel injectors. On GM vehicles, we flush the fuel injectors when we determine the injectors are at fault. I believe there is a TSB for it also.
And is this miss very noticable?
Old 07-05-05, 08:55 AM
injectors
My 97 Lumina had random rough idle on start-up and set misfire codes on random cylinders. It only happened on start-up and never started when the engine was running normally. It happened maybe 1 in 20 stars and I spent 6 weeks pulling, inspecting and swapping plugs, wires and coil packs.
I read on this site to add 2 bottles of injector cleaner to the tank. I did not believe it, but I tried it anyway and have not had the problem since.
I hope your problem is this easy.
