Getting off A Destroyed Oil Filter on my 'Cuda
Old 07-05-05, 05:16 PM
angellinda
Unhappy Getting off A Destroyed Oil Filter on my 'Cuda
Hi;
Any good suggestions tried & true would be appreciated! My husband destroyed my oil filter on my 'Cuda. It wasn't changed in like 10 years! So its destoyed yet the seal isn't broken so its stuck as am I from going to the Midwest's Largest Old Car Show in Iola, WI. Any ideas"?? He's so mad!! My car is so not going any where!! I'd like this solved anyone that knows the "E-bodies" of the muscle Mopars know ther isn't much room to move around! Help!! Please Reply!! Thank you, Mopar Girl in WI.
Old 07-05-05, 05:18 PM
big screwdriver
Run a big screwdriver thru both sides and turn.
Old 07-05-05, 08:20 PM
the_tow_guy's Avatar
Or take a chisel and make a small notch in the rim near the block. Then use a punch or screwdriver (or the chisel itself) in the notch and hit it with a hammer.
Old 07-05-05, 08:49 PM
I've had to do this when a filter wrench merely squashed the filter on a Plymouth Gran Fury with a 318
It probably hadn't been changed in 5 years or more
It didn't look pretty, and it made a mess, but it worked
Old 07-05-05, 08:59 PM
Lugnut's Avatar
Ok, I'll play the trump card now.
Take it to Jiffy Lube just this one time.
Old 07-06-05, 04:28 AM
On a tow truck!
Old 07-06-05, 06:20 PM
30+ years ago before I could afford a oil filter wrench [yes I was that poor] I always stuck a screwdriver through the filter so I could loosen it. Works well just messy. If the filter is too mangled for that tow guys suggestion of using a chisel will work great.
