82 Toy4x4carburated*surging*
Old 07-08-05, 12:20 PM
STV
Question 82 Toy4x4carburated*surging*
Hi there, I need some help on my 1982 toy4x4 that is carburated. The truck when cold starts ok but surges a little but goes away when completly warmed up. If I let it sit for 5-10 minutes it will not Idle when I restart it.It will surge while I'm driving,but once it is warmed up it's fine.
Help GEAR HEAD !!!!
Old 07-08-05, 09:18 PM
billys68ss's Avatar
Has the carb seen any maintenance? It is possible that the floats are sticking a little. Does your Check Engine light work? Is it on? You might want to see if you can pull some codes to see if something is stored. There are still several things that could be wrong with this somewhat simple system that could be causing these conditions.
Hope this is helpful to ya,
Billy
Old 07-10-05, 08:07 AM
Your really bringing me back on this one.
There is an aux accel pump on this carb (located I think in the front of the carb) that the diaphram would rupture and cause these problems.
Too old for me to send you repair info.....try your local lib
