2000 Toyota Camry
Old 07-09-05, 11:25 AM
drj3565
2000 Toyota Camry
I have a 2000 Toyota Camry the check engine keeps coming on it shows a code 446 Evaporative Emission Control System Vent Circuit Malfunction
I have changed the gas cap two times now so I do not beleve that it is the gas cap . What else could cause this code. My Camry has a 4 cylender engine in it.
Drj3565
Old 07-09-05, 03:19 PM
billys68ss's Avatar
Could be a line that is damaged or a bad vent valve. There are three vent valves on that particular vehicle. You should probably get it smoke tested in case it is a damaged line. Otherwise you will need to test the vent valves.
Let me know if you need further information.
hope this helps ya,
Billy
Old 07-09-05, 05:04 PM
drj3565
2000 toyota camry
tell me what you mean by a line being damaged and what and where would i find the vent valves.
drj3565
Old 07-10-05, 08:00 AM
Your better off having it checked at the dealer. There are two valves it could be (also a lot of other things).
Bypass vac switching valve or closed canister control valve.
