1997 lumina how to change brakes
Old 07-10-05, 06:37 AM
darth_raj27
I'm trying to replace the rotors and brake pads on a 1997 lumina sedan and cannot get any of the bolts loose I'm assuming there are two bolts (torx) to remove the entire assy. and 2 other bolts (sae) to replace just the pads any help would be appreciated.
Old 07-10-05, 06:54 AM
P
You're correct - saddle bolts are 60 torx, caliper bolts are 15mm head. Saddle bolts carry loctite from the factory. Best method I've found is a breaker bar and/or cheater pipe.
Old 07-10-05, 07:08 AM
darth_raj27
re:lumina
Thanks for confirming what i thought
