84 Toyota Corolla Hatchback
Iam trying to tune up my daughter's Toyota. I changed the plugs, replaced the air filter, changed the oil and filter and ajusted the idle speed. What I can't do is check the TIMING. My manual says to check the VECI label located inside the engine compartment. It is not there and not in the manual either. Can you guys tell me what the proper timing should be???.
The manual gives several kinds of 84 Toyota models. This one has a Carburator, whick is different from the others.
HELP PLEASE.....
HELP PLEASE.....
