Please Help Me (Battery or fuse problem)
Old 07-14-05, 07:09 PM
BIGGMIKE3615
Angry Please Help Me (Battery or fuse problem)
i HAVE 97 FORD TAURUS THAT HASN'T BEEN DROVEN IN A WHILE. ME & MY BROTHER PUT A NEW BATTERY IN THE CAR, ONLY TO FIND THE RADIO, SPEEDOMETER, GAS METER, WIND SHIELD WIPERS, WINDOWS, TAIL LIGHTS AND INTERIOR LIGHTS DOESN'T WORK. IS THIS A FUSE PROBLEM? i CHANGED A COUPLE OF FUSES AND NOTHING HAPPENED. PLEASE HELP ME
Old 07-14-05, 07:40 PM
Does the car start?
Old 07-14-05, 10:49 PM
Does anything work?
If not, make sure the battery cables aren't reversed and the chassis ground, the smaller black wire from the battery to the chassis, is connected and corrosion free and the battery terminals are clean and very tight around the battery posts. Also check the large 175 amp megafuse located in the fuse box in the engine compartment.
Old 07-16-05, 06:53 PM
Toyota_Doctor
I would have to agree check the main fuse to see if that's good. Look for anything loose. Check to see if the timing belt is intact. Will the thing turn over? Make sure battery cables are observing polarity ( Neg on Neg Pos on Pos ) Hit me up if you get the beast running, or don't I can help you.
Later,
Bart
Old 07-16-05, 07:09 PM
Lugnut's Avatar
It almost sounds like the 'accessory' circuit is disconnected, except the tail lights would still be working, but you say they aren't.
As mentioned, I would check the chassis ground. Perform a simple voltage drop test. You should get a 12 volt reading between the positive battery post and the car body.
Old 07-16-05, 07:16 PM
You need to have the BCM (I think Ford calls it a "Generic Electronics Module") checked for communication/reset. If the car starts and runs, that's the only thing all of those accessories/systems have in common.
