1993 Mazda 626 Won't hold charge
Old 07-16-05, 07:15 AM
Ray Scott
I have a 1993 Mazda 626.
I have put in a new battery and alternator.
The battery was fully charged before installation. It held for 2 days.
I've checked all the wiring from the alternator to the battery, I changed the ground cable. Recharged battery at Auto Zone, still will only last two days.
Why is my charging system not working?
Ray
Old 07-16-05, 08:36 AM
Lugnut's Avatar
Occasionally rebuilt alternators are defective right off the shelf. Start your engine, then get a battery voltage reading. It should be at least 13 volts with engine running. If not, then your alternator is bad.
Old 07-16-05, 04:41 PM
Bubba Bob
It could also be the fan belt. How long has it been since it's been replaced?
Old 07-16-05, 04:51 PM
Your charging system may be working, you may have a drain on the battery
Try Lugnut's test
Test the voltage after the car is shut off
Test the voltage the next morning before you turn the key
