Rear view mirror fell off
The rear view mirror on my wife's old Berreta fell off, after being parked in the really hot sun all day.
Is there special glue to reattach the base plate, or will any super glue work?
Rich
Rich
Acetone
Try Acetone (nail polish remover) Have plenty pf ventelation.
Right from the WEB:
How to Remove Super Glue
Superglue (cyanoacrylate) has many uses. Besides the typical household function of sticking things together, it's used in surgical procedures and even in crime labs to develop unseen fingerprints. Originally marketed as Eastman #910 in 1958, this stuff is sneaky and it goes everywhere if you don't keep an eye on it.
Steps:
1. Clean up any glue that is still wet by blotting it with a white paper towel or terry cloth towel.
2. Soak the object in warm soapy water if possible and try rubbing off as much as you can.
3. Pour a little bit of acetone-base nail polish remover on a white terry cloth.
4. Dab at the dried glue until it dissolves.
5. Use extra fine sandpaper to remove dried glue from the surface of an object.
6. Try a product called Goof-Off or Z-7 Debonder.
Tips:
Hold a folded white cloth on the back of fabrics to keep the acetone from soaking through other layers.
Acetone may affect colors or melt plastic fibers, such as some nylons or carpet. Test it on a hidden area first.
Warnings:
Don't use solvents such as gasoline or paint thinner.
Tips from eHow Users:
Remove super glue from skin by claudia
Rub on hand cream, then wash the spot with warm water. It may take a few washings before the glue comes off.
Rate this tip:
Removing superglue from skin by Melissa
I got super glue on my finger, I rubbed body lotion on the area, rinsed it under warm water, and used the green scrub on the other side of a sponge. It worked like a charm!!
Rate this tip:
View 4 More Tip(s) from Users Please Share Your Tips with UsIt's easy!
E-mail this page to a friend Write an eHow ArticleNew!
More Resources:
Related eHows:
Get Wax Off a Tablecloth
Clean Ink From Carpet
Remove Wax From Upholstery
Remove Glue From Carpet
Remove Bumper Stickers
Clean Up Silicone Caulking
Related Ads:
Super Glue
Elmer's Glue
Glue Remover
Glue Stick
Glue Tape
Project Details:
Skill Advisory: Easy
Printable Page
Right from the WEB:
Steps:
Tips:
Warnings:
Rate this tip:
Rate this tip:
More Resources:
Related eHows:
Related Ads:
Super Glue
Elmer's Glue
Glue Remover
Glue Stick
Glue Tape
Project Details:
Printable Page
