Fans..cooling
Old 07-17-05, 10:06 AM
Fans..cooling
Im Lookin To Move As Much Air As I Can.......what One Is Best At Doing So...stock Clutch Fan....aftermarket Flex Fan.....or An Electric High Performance Fan...
Old 07-17-05, 12:37 PM
Depends on what you've got
Stock fans are usually pretty good, a shroud might help if you don't have one
Flex fan is more for reducing drag at higher RPMs, though they do tend to move more air at low RPMs than stock
Electric fans can be pretty efficient and move alot of air
A double electric fan set-up is probably the most direct answer to your question
It'll probably have to be fab'd up though, a custom job
...but it'll sure move some air
Old 07-20-05, 04:27 AM
Thanks
Pretty Much What I Was Thinking As Long As You Get The Correct Electric Fan For The Job...some Are Not Gona Cut It On Their Own
