Fan problem
Old 07-20-05, 01:10 PM
BluenoteForever
Fan problem
I have a 1996 Pontiac Sunfire with a 4 speed control on the fan controlling both the amount of heat or the A/C. The fan will not work on the lower 3 settings (simply quit when I was driving today) but works perfectly on maximum which blows air full blast. On the maximum, the A/C also works properly when I push the A/C button but again not on the 3 lower settings.
Any suggestions on what I should be looking for? Would it be a relay switch?
GB
Old 07-21-05, 03:11 AM
sounds like a bad blower resistor or blower control module, not sure which your car uses, both parts have the same function the module just does it electronically instead of using resistors.
