93 Camry a/c, heater fan trouble
I have a 93, 2.2L, 4cyl, Camry. I was on a long road trip on a hot day when my climate control fan stopped running. I checked the fuses and they appear to be fine. I may have burned out the fan motor. How do I check/repair this without ripping apart my dashboard too badly? Any help would be greatly appreciated. Thanks
Received 0 Votes
just check with a testlight to see if you are getting power and ground to the blower motor it shouldn't be to difficult to get to probably under the passenger side dash you probably do not have to remove any of the dash to access it.
the resistor located near the blower motor is usually held in to the ductwork with a couple of screws is also a very common problem of causing the blower motor to not work.
