1992 F150 power windows
Old 07-23-05, 06:27 AM
The drivers side window goes down fine and starts up fine and then it stops at a certain point and wont go past it, I have to do the rest by hand. Motor or something else? Thanks
Old 07-25-05, 05:18 AM
the_tow_guy's Avatar
Probably the motor. Fairly common repair item after they get that many years on them. Not a real difficult fix on that vehicle if you're handy.
Old 07-30-05, 08:16 PM
busman
Cool power window
Make sure that the window regulator moves freely without binding. You will have to disconnect the motor to see that the window moves freely up and down. If that checks out then the motor is the problem. Good luck!
Trackbacks are On
Pingbacks are On
Refbacks are On
