Master brake cylinder-94 Chev.Suburb.
Old 07-23-05, 09:02 AM
How can you determine if the master brake cylinder has gone bad?
TIA, Frank C.
Old 07-23-05, 09:18 AM
P
There can be many different symptoms. One of the most common is the pedal fading after initial application or after coming to a complete stop. If you are experiencing pedal fade, pinch off all 3 flex hoses and see what happens when you apply the brakes (engine running). If there is no fade, pedal solid, your master is fine.
