1994 Toyota Celica won't start after battery was disconnected
Old 07-23-05, 07:39 PM
ssmith1347
I am working on a 1994 Toyota Celica. I disconnected the battery to diagnose a starting problem. When i reconnected the battery the car won't start. the flashers on the car are flashing after i connected the battery. I checked with a test light and i have power to the large post on the starter, but no power to the small post when the key is held in the start position. i can make the engine crank by jumping from the large post on the starter to the small terminal. I am wondering if the problem could be in a anti theft device on the car. Can anyone help me?
Old 07-24-05, 10:48 AM
Is it a factory or aftermarket anti theft device?
Old 07-24-05, 11:11 AM
ssmith1347
1994 Toyota won't start
It is a factory anti-thieft system. I found the remote in the glove box, and tested the battery in it. It showed 7 volts. I replaced battery with a new one, 12 volts, disarmed the alarm system, and the car started fine. Thanks for you help.
