Is the Master Cylinder supposed to squirt brake fluid upward with cover removed?
Old 07-27-05, 12:44 AM
FL410
96 Suburban 1500. When the brake pedal is pushed in, with the MC cover removed, the fluid squirts up from the primary enough to clear the resevoir. I assumed it was the bad MC, but the refurb one does it also while pre-bleeding it. opinions anybody?
Old 07-27-05, 03:47 AM
its normal and does not indicate a problem.
Old 07-30-05, 03:21 PM
grhow
Yes,that is why you loosely set the top of it on to prevent pouring out. I always bled each wheel cylinder also,while keeping the master cyl. full.
