Help! Engine Shuts Off After Cranking..
Old 07-27-05, 10:17 AM
milkdog
Exclamation Help! Engine Shuts Off After Cranking..
After replacing a 2.0 liter engine with a previously running 2.3 liter engine and making some modifications, engine starts right up then shuts down after a few minutes,but cranks back up again only to shut back down.
Any suggestions on what to check?
Old 07-27-05, 11:03 AM
Lugnut's Avatar
Perhaps it is running is open loop (computer) and when it changes to closed loop a minute later the engine dies. Perhaps you need to change the computer to the one that matches the new engine.
Old 07-27-05, 01:09 PM
milkdog
already did that...
already did that,changed computer,wiring harness...whole nine yards.
Old 07-28-05, 10:06 AM
milkdog
Exclamation did propane test
I put a 45 psi inline fuel pump to replace the mech.,I already used the "propane test", and it still cuts out...
HELP????
Old 08-06-05, 07:22 AM
milkdog
Exclamation Please...i Still Need Help??? Anyone/???
CHECK THE PROBLEM I HAVE DISCRIBED..AND PLEASE...ANY IDEAS WOULD BE WELCOME....I NEED TO GET THIS THING ON THE ROAD....
