99 malibu dead computer
Old 08-01-05, 02:22 PM
duke spinner
car quit , dash digital odometer is blank, scan tool can't communicate w/ computer
now it does start, scan tool, no communication, display still blank ..runs crappy, of couse
checked fuses, ok
where is computer physically located ..??
does it have the VIN # on it ..??
i am very suspiscious that the computer is a replacement to hide the originlal mileage.....
there has been an unbeliveable number of repairs to this POS, suppossed had 12k on it when purchased.................
Old 08-01-05, 03:06 PM
Lugnut's Avatar
I agree that the computer may have been swapped out in the past. However, before you conclude anything, be sure that you are following the correct procedure for your specific reader for pulling codes. For example, if your code reader requires the make and model, engine, etc, then be sure you select the correct options.
Old 08-01-05, 03:46 PM
duke spinner
dude ...
it's OBD2 ....
the dash fields that display computer generated data are black...
computer meltdown, i would say, need to find the unit to check ground, etc
if a rebuilt was installed, it makes sense it crapped out .....
thanks for taking the time to reply ...
Old 08-06-05, 07:20 AM
snozuloz
If the computer is bad, it should fall under the 8/80 warranty for emissions items. Not sure what your mileage is.
However, I have seen ignition switches cause similar problems to what you are experiencing.
Old 08-07-05, 07:40 AM
duke spinner
don't foget, t runs ... badly ..
i think that would rul out the IGN switch ...
still lookin' for the ECM .....
Old 08-07-05, 10:56 AM
Have you looked behind glove box?
Old 08-07-05, 11:05 AM
The ign. sw. is often in a direct line from the battery to the ECU relay
A faulty switch could make the computer unreadable by a scanner in the KOEO mode, yet the vehicle can start and the ECU can be read in the Engine Running mode
I think you're comp is toast though
Sorry I don't know where they are on a Malibu
