Temp Sensor Not Reading Right
Old 08-01-05, 05:41 PM
chevyastro4x4's Avatar
i brought a new sensor for my van and im woundering if its reading wrong because 10mins after starting it it says its over heating but i can grab the outlet hose and it warm, but not hot, and advace auto parts wont exchange it because its been used
Old 08-01-05, 05:48 PM
You can test them by heating them up
The test procedure varies depending on what type of sensor it is
Are you sure it's not the gauge itself?
Advance should take it back if it's defective
Old 08-01-05, 06:09 PM
Or hey, I'll test it for you:
Q: does it work?
A: ..................well, to me it looks like you're saying "no", so if you don't mind I'll put down that as your answer
A: No
Hey you just had it tested (by me) and I say "it's out of spec"
Advance should take it back now, you had a guy test it for you, and he said it was out of spec
If you want another one tell them I said it could just be the wrong one so double check the numbers
Old 08-01-05, 06:25 PM
i went back to advance and chewed them out and one of the guys there said alot of time they read some of the heat from the exhast, and this sensor for the gauge is right between spark 1 and 2
Old 08-01-05, 06:26 PM
Q: does it work?
A: No
