1992 mitsubishi expo sp - Fuel pump?
Old 08-01-05, 08:01 PM
petalz143
I have a 1992 mitsubishi expo & it will turn over, but it won't start. Is it the fuel pump? If so, where is it located, inside or outside the gas tank? How do I replace it? Thanks!
Old 08-02-05, 06:19 AM
you will need to either diagnose the vehicle yourself or take it to a shop but there is no way of knowing what the problem is without you running some test to help narrow down the problem such as if the vehicle is getting spark?
if no spark is the ignition rotor turning when cranked over.
if it has spark you should check fuel pressure and check for injector pulse using a noid light.
it could be a bad fuel pump but chances are its something else, and the pump is most likely inside the tank.
