ABS problem 01 silverado "follow up"
I removed wheels,calipers,rotors,and sensors for each wheel. I then cleaned rust that was raised up thoroughly,I even sanded metal surface to be sure. I put everything back together to find out this did not solve the problem with the ABS system kicking in right before I come to a complete stop.
you have a sensor that is reading incorrectly a scanner will need to be hooked up to the vehicle while it is being driven to see which sensor is dropping out and reading zero before the other sensors suggest seeing a shop.
