where's the thermastat on a 93 ford probe
Old 08-06-05, 01:53 PM
dannuscis
I need to replace the thermastat on a 93 ford probe.
I see to many hoses and and the one I pulled off housing its not there
Old 08-06-05, 03:57 PM
Comptech
What engine?
Old 08-06-05, 09:06 PM
Follow the top radiator hose back to the block it should be at the end of the hose on the engine
Old 08-06-05, 11:17 PM
jeffstevens
So you need th change the thermostat, what's the problem? Running Hot? Make sure the electirc cooling fan is working. maybe relay. I have seen some overheating issues with a thermostat stuck closed, When its over heated it will stick open and in the winter where you are may run into a problem to cold.
I'm from Canada's Arctic N.W.T.
