95 s10 blazer-obdII code 122,and 1406
1995 jimmy 4.3 vortec ,hard starting cold and hot,misfires,eraticle idle,rich exaust,obd II 122,172,1406.
what possible reasons for set code. almost all sensors new problem not fix.i appreciate all imput.
95 s10 blazer
TPS already new. Is the throttle/pedal position sensor the same as the TPS?
What is code 1406? Cannot find it in my book. thanks for all input.
TPS is throttle position sensor.
Check the EGR sensor, a hose maybe plugged or off. Also you may have to replace sensor. New part is around $100.00
