Emissions Code, 2000 Taco
Old 08-08-05, 03:57 PM
mako's Avatar
2000 Tacoma, 81K miles, 2.4l 4-banger, 5spd, fresh oil two weeks ago. 89 Octane, clean-ish air filter.
Code is P0420, "Catalyst System Efficiency Below Threshold Bank 1".
Did this same thing almost exactly a month ago, but was running fine. I erased to the code to see if it would come back or if it was just a burp of some sort in the exhaust system. Came back just today.
I'm not a mechanic but know a lil, and just happen to have a pocket code scanner. I know this thing is telling me something is up with my cat, but what exactly am I supposed to do about it? There's two codes for this exact same description and two codes for "Bank 2", so in addition to what's going on with my truck, what is the difference between these 4 codes?
Any help is greatly appreciated. I've never had problem one with this truck, so I'm a bit befuddled.
Old 08-09-05, 03:08 AM
The cats not working....possibly had a dirty air filter at onetime?
Try running the hell out of it in 2nd gear to get the cat good and hot.
Clear code and see what happens.
BTW 89 oct no good, designed for 87. Computer assumes 87 and will not burn 89 or higher as complete.
Old 08-09-05, 04:32 PM
mako's Avatar
Thanks for the octane info, I actually do run 87 octane I just goofed with the typo.
I'd already cleared the code, but it did nothing on the way to and from work today (20 miles, half of which stop and go, half 55mph).
Is this something I need to take to a pro and have checked out, or should I wait for it to become consistent?
Old 08-13-05, 05:31 PM
mako's Avatar
The same code came up today, was doing about 50 in 5th gear. What am I supposed to do? Is this a "replace the cat" kind of thing?
Old 08-15-05, 05:25 PM
mako's Avatar
Anybody? I am getting the code on a daily basis now. P0240. What am I supposed to do to this truck?
Old 08-15-05, 05:55 PM
Yes you are going to need to replsace the cat. It is covered for 80,000 miles. If you are a good customer at the dealer they may work with you.
Old 08-16-05, 05:09 PM
mako's Avatar
Thanks Toyotaman. I'll be contacting the dealership soon. They've been good to me so far.
Matt
