97 Aerostar 3.0 L Egr flow sensor
Old 08-08-05, 08:59 PM
R
Does anyone know where the EGR flow sensor is located on the 3.0L 97 Aerostar engine?
Thnaks in advance
Old 08-08-05, 09:21 PM
jeffstevens
DPFE sensor measures your exhaust, what problem do you have? running rough, check engine light? there should be a couple branches off the egr tube, follow them up to the dpfe.
Thnaks in advance
Old 08-09-05, 08:59 AM
R
Thanks for the reply Jeff
Yup the check engine light is on. It is giving 2 error codes. One for low EGR flow and High EGR flow. The engine is running smooth.
Old 08-09-05, 09:24 PM
jeffstevens
Check the DPFE a hose may be off, if not it could be a faulty sensor. What are the error codes?
Old 08-10-05, 10:19 PM
R
There were 2 error codes
P0401
P0402
