Air not as cool
Old 08-10-05, 12:52 PM
jm_wilson
Air not as cool
I have a 96 Blazer. I thought my problem was fixed, but I still think I have a problem. I checked the low side and the reading is between 44 and 54. The condenser is cold. I used to get a lot of condensation tripping, but none now. Todays temp is 94. I tried to add freon, but it didn't seem to take it. The cooliing used to be great in this car.
Old 07-16-06, 08:57 PM
davzack's Avatar
What are the high side readings?
Old 07-17-06, 06:57 AM
Your getting a little high there on the low side. A high side reading would behelpful. the condensor should be very very hot. The evaporator should be cold. You may want to verify the blend door operation it could be stuck partially open letting heat in
Old 07-17-06, 09:02 AM
the_tow_guy's Avatar
Check to see if you have a filter screen that needs cleaning. Cooling in my wrecker got way better last time I cleaned mine.
