Ford Ranger '94 rear axle seal replacement
Old 08-13-05, 06:36 AM
CoachBenz1
Need to replace rear axle seal on '94 ranger. Do I need to pull axle out to replace? If so, how do I accomplish this. How is the axle locked or attacked into the Differential? Is this a simple operation or will it require special tools ect. Thanks in advance, CoachBenz1
Old 08-14-05, 07:17 AM
hogfan's Avatar
Remove rear end housing cover
Remove 5/16" headed bolt going thru the pin (in gear set)
Remove pin
Push the axles in and remove both "c" clips
Pull axles out
