1997 buick lesabre crank position sensor replacement
Old 08-13-05, 08:24 AM
garcb5
Need some help with replacement of crank position sensor on 1997 Buick Lesabre. Do I have to remove the harmonic balancer first. Any info will be greatly appreciated, Thanks
Old 08-13-05, 12:44 PM
if its a 3.8 yes you have to remove balancer and most have a plastic shield installed around the balancer and crank sensor that needs to be removed if its still there.
there is 3 bolt holes in the balancer they are very small and an odd size cant remember size, but you can use a balancer puller if you need to.
Trackbacks are On
Pingbacks are On
Refbacks are On
