grand cherokee won't start
Received 0 Votes
other day...94 grand cherokee (6 cyl) would crank but would not start...finally got it to turn over...ran fine that nite..next morning..same prob...have recently switched from mid-grade gas to regular...possible fuel injector problem?....threw a bottle of injector cleaner in tank...but obviously cant work without car running...actually changed plugs today thinking maybe foul plugs...still wont start...HELP
Received 0 Votes
check for spark at a plug for starters if you have spark check fuel pressure and injector pulse.
I think you can also check codes by cycling the key on and off 3 times leaving the key on and counting check engine light flashes it will flash each code once so you may have to do it a few times to get the codes if any 55 is end of codes.
