tires backward
Old 08-19-05, 06:51 AM
tires backward
I have a 2001 Neon I bought new.The man at the garage fixed a flat for me and said he noticed my tires were mounted backwards.He said they were concentric tires.They have a uneven tread pattern on them.Have you ever heard of this and how much does it matter?
Old 08-19-05, 08:19 AM
Received 89 Votes on 78 Posts
Yes, some tires are meant to travel only in one direction. How much tread is left on the tires (if you don't know, how many miles are on the tires)?
Old 08-19-05, 11:53 AM
tread
There is quite a bit of tread left on the tires.The car has 36000 miles on it .I have had it since 32000.I think it is the 2nd set of tires.Do you think it would be wise to have them remounted?
Old 08-19-05, 01:17 PM
Time to start thinking about it. What brand and model tires are they?
Old 08-19-05, 01:22 PM
it will say on tire
Some place on the tire it will say use only with this rotation and have a arrow
Old 08-19-05, 02:17 PM
E
Eddiebx
the mounting direction is more important for wet weather performance, you probably wouldnt' notice a major differnce in teh dry.
Old 08-20-05, 10:03 PM
If you determine the tires are on backward, don't remount them, just switch them to the other side of the car. If they are due for a rotation, switch them from front to back as well.
Old 08-21-05, 01:01 AM
E
Eddiebx
well some tires have asymetrical treads, so theres acutlly an outside and an inside on the tire, not just a left and right. in that case you woudl need to remount them if u want them to face the right direction
Old 08-21-05, 06:12 AM
backward tires
You are right on.The tires have a inside and a outside edge.I would have to remount them.Thanks for the help.You learn something new every day.
Old 08-21-05, 08:56 AM
If the tire had an inside and an outside edge with directional tread, would the manufacturer not have to make two different tires that were mirror images of each other to fit both sides of a car?
Old 08-21-05, 01:53 PM
No.no..no..
Old 08-22-05, 03:16 PM
Thumbs up
Wow, on a Neon? Usually, unidirectional tires are on aggressive sports cars costing considerably more than a Neon. No offense intended, but I don't believe that they even make tires that size that are unidirectional. As previously stated by michael van, there would be arrows on the side on the tire to let you know the direction that they were intended to turn.
Could you please let us know the outcome?
