1992 ford aerostar van
Old 08-19-05, 07:39 PM
neta
I have a 92 aerostar and having trouble with it starting and when I do get it started it dies after I drive it awhile it has a new battery and I also put a new inertia switch . I havent put a fuel pump on it but I was told that it was ok.
Old 08-20-05, 12:17 AM
when it doesnt want to start you should check it for spark and also test fuel pressure you may have to drive it around till it dies and then check for the above you can remove the inside engine cover to gain better access to the coil wire if its a 3.0l it should also have a test port on the fuel rail that a fuel pressure guage will connect to.
if you have no fuel pressure you can test for power at the inertia switch using a test light it should have power for about a second after turning the key on.
could be ignition or a fuel related problem will have to do some test to narrow down which one.
