ac clutch
ac clutch
1993 Mazda 626 v-6
Ac clutch does not ingage. Tried to top off with 134. Clutch would not engage. Checked fuses and put ac relay in same model car. The clutch on that car did engage or so the boy said. Tried crossing the cycling switch, still no go. What next. Any idea how to ohm the ac relay (6 trminal)? Wasted one can of 134 and one can of oil
I just had the same problem with a 98 Honda. After checking the clutch coil continuty and finding it ok, I connected the battery directly and the clutch did not respond. Checked Battery voltage and it was low. Checked Alternator and it was producing at the low end. Changing the battery and alternator solved the problem.
