Transmission fluid??
Where do i check the fluid and add fluid in a 1999 Grand am 4 speed auto transmission? I feel silly but I can't find it. And of coarse the little manual says, take it to the dealership! NOOOOOO
Thanks!!!
Thanks!!!
Fill level plug on a 4T40E
If you cannot find a dipstick then you must have the 4T40E which is an electronically controlled 4 speed version of the 3T40 (which as the name implies is a 3 speed). They did away with the dipstick and put a fill level plug in. It is on the passengers side of the vehicle underneath the car by the passenger side axle shaft where it enters the transaxle. You must remove the fill level plug, when the vehicle is running in neutral and it should run out if full, kind of like we check a manual transmission only the car is running. The plug is a 7/16" and looks just like a pressure tap plug.
