96 chevy 4x4
Old 08-22-05, 11:25 AM
tontorodregus
Cool 96 chevy 4x4
Started motor, turned on air,truck died.Has never gave any problems in the past.But now the engine turns over but doesnt start for lack of fuel and fire.Checked all fuses,All fuses under hood and inside cab are good.seems strange that the fuel pump,all gages,all waning lights,turn signals,and fire from distributor, would all quite at the same time.Also the gear selector can be put into gear without applying the brake. headlights and dash lights as well as interrior lights work.i have checked every wire and connection for damage.
Old 08-22-05, 01:17 PM
B
if you have power to most all of your fuses in the fuse box it sounds like an ignition switch problem there will be a couple of fuses that will not have power like the crank fuse will only have power when the engine is cranking over and instrument lamps fuse usually only has power when the lights are on.
if alot of fuses do not have power to them check the large fuses in the underhood fusebox.
