Air not blowing out
Old 08-25-05, 06:57 AM
tidewillroll
Air not blowing out
93 Honda Accord. The air doesnt blow out, no matter what the settings. You can hear the Air condition unit cut on but no fan. Help Please!
Old 08-25-05, 09:54 AM
D
When is the last time it runs? Have you checked fan motor is it good or bad? You can check it by direct hook up to your car battery. How about fuse in fuse box? I would suggest you to check electrical fist. I got 90 Honda Accord which is the same model like yours. Good Luck!
Old 08-25-05, 10:04 AM
D
Since I got the same model like yours, I got a question for you. My Accord used to run 23.5 - 24.5 miles per gallon (34 miles a day, 1/3 local and 2/3 highway with some traffic) in the past 2-3 years using Costco gas. I kept recording mpg very consistence for the last 5 years. I recently changed all four tires and store my car for only one week, the car now is running ~22 miles per gallon. I was wondering how's your MPG in your car? Which gas do you normally use? Thanks!
Old 08-25-05, 10:09 AM
look down a few threads for 94 chevy astro read that
