help repairing lincoln ls elec window driver side
Old 08-29-05, 06:18 PM
durango1
Daughters LS drivers side window dropped inside the door. Took the door pannel off and found that one of the window support bars that have the nylon rollers on broke the one that is closest to the door middle post. Also found the brackets that connect to these plastic brackets that have a metal bracket connected to it in the bottom of the door. In short all in pieces. Also the cable got tangled around the motor and does not look good.
question
1 is there a diagram where i could see how this all went together.
2 where is the best place to get the motor and-
the bar with nylon pullys
3 does the motor come seperate from the cable.
like i said all was in pieces and dont have a good positive idea how this all was assembled.
4 im more so interested with a diagram so i can hopefully get the parts and fix for my daughter.
thanks to all who reply
Old 08-29-05, 09:19 PM
Best thing to do as far as a diagram, might be to take the passenger side door panel off and if that window is built the same way, you can use that as a guide.
Old 08-30-05, 03:12 AM
just get a new regulator, if you can hear the motor running it is probably okay, you will never piece back together your existing regulator without it coming apart again.
