radio removal 94 s 10
Old 08-30-05, 11:35 PM
Redwards1969
Question radio removal 94 s 10
how do i remove the radio out of a 94 s 10?
Old 09-01-05, 02:05 PM
chevyastro4x4's Avatar
Most dash trim plates on these vehicles are retained by screws and/or snap fasteners. Make sure all screws are removed before attempting to remove the trim plate. If retained by snap fasteners, it may be necessary to pry the plate loose, BUT take care not to force and break the usually fragile plastic pieces.
If necessary, remove the heating/air conditioning control head. For details, please refer to the procedure in this section.
Remove the radio bracket-to-instrument panel bracket screws or nuts, then carefully pull the instrument panel center compartment forward with the radio.
Unplug the antenna lead and electrical connectors, as necessary.
Remove the radio from the vehicle.
