Replacing tie rods GMC Jimmy 2000 Help please
Old 09-04-05, 11:28 AM
hostapparel
Looking for instructions on placing tie rod ends 2000 GMC jimmy 150,000 miles, inside wear on both front tires, jacked car get movement push pull front wheel left, right, top bottom, no movment.Price of gas, must do these repaires myself. Thank you for any ones help.
Old 09-05-05, 01:49 PM
If you jack that vehicle up and just shake the wheel side to side you will get play on a brand new one.You are over riding the idler arm preload when you do that.One the ground with the suspension loaded the idler arm will not allow that movement.Have some one rock the steering wheel side to side a couple inches and watch for play in the tie rod ends.You may have worn parts so check them first but the wear may be from alignment being out of specs most likely toed out.
